Home > Maintenance & Mods (L322) > New torque converter :(
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Not bad I suppose just hit 130 k and still on first TC, so been down the gbox expert by me and a new TC oils gaskets flush and tcc sensor all supplied fitted £800 decent price you think _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #252732 4th Apr 2014 5:03pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Seems not bad for a fitted price Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #252835 5th Apr 2014 5:26am
About 100 pounds less than most I have heard of and look on the bright side , you have a new torque converter Thumbs Up
( key board can no longer do pound signs ) 2008 MY Supercharged
Post #252839 5th Apr 2014 6:47am
Can I ask what symptoms you had on the car that made you change the torque convertor?
Post #252871 5th Apr 2014 10:37am
mjdronfield
Do they do upgraded ones ?
Though I suppose if the standard unit has lasted that long...........
Just wondered if, for a little bit extra, it could be beefed up.
Are you having any gearbox work done at the same time ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #252895 5th Apr 2014 12:05pm
Scottyav
Vibrates at 55 ish to 65 when it reaches the lockout in top cruising, you can feel the vibrate through seat and rangey, let it get too bad and it takes the whole box which is about 1400 even though on eBay you can get a full recon box fitted for £1150 I don't know them _____________________________________________________
Post #252925 5th Apr 2014 2:02pm
I'll look out for that. Thumbs Up
Hopefully not for a while. Smile
Post #252946 5th Apr 2014 3:13pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Getting my TC changed next Friday, had the classic symptoms as explained in various threads by RRPHIL. Local indie checked the oil in the box first and no metal particles so hopefully the box is ok - the oil however had been cooked when the box went into overheat due to a blocked rad a while back.
Going to have the box flushed at the same time.
Fingers crossed this fixes it. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #252953 5th Apr 2014 3:33pm
MrP
So gearbox power flushed and filled with lovely nice new gearbox oil, they added an additive to help keep the seals nice and flexible and a nice new torque converter installed. So far it seems to have cured all of the symptoms I had before. The box feels like it is changing gear earlier and is smoother. Had a look at mpg and it too seems to be slightly better. So far so good Smile "On first name terms with my local Dealer......now."
Post #254598 15th Apr 2014 7:05pm
