Home > Maintenance & Mods (L322) > Injector testing
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Injector testing
Apart from pulling them one at a time, is there anyway to check the injectors without removing them for a squirty in the bottle test!?
Also am I right in thinking that to remove injectors 2-6 the inlet manifold needs to come out?
Post #253024 5th Apr 2014 8:39pm
adigorn
you can do a spill test when they are still fitted
(and test them with t4)
i know its not a FULL test but will give you pretty good idea about the condition
yes manifold off to remove them
Post #253034 5th Apr 2014 9:41pm
paul271
Cheers mate.
Forgive my ignorance but T4?
Post #253041 6th Apr 2014 12:32am
adigorn
Sorry i was refereeing to the testbook machine
any other computer able to do injector balancing will do as well
Post #253047 6th Apr 2014 6:14am
Looks like standard IIDTool will give fuel pressure live value only. Torque Pro on an Android Phone with ELM327 might give more info?
Haver been searching for a photo howto on spill/leak test for FFRR, closest was something on a Beemer.... .
Post #253056 6th Apr 2014 9:37am
paul271
I think I'll end up checking out the Beemer ones Joe. As long as I get a rough idea I'll suss it out!!
Post #253078 6th Apr 2014 2:18pm
Yip leak off test will help but ideally after 100k they tend to just be best being removed and tested.
Strangely when fitted in BMW's they seem to eat through them a lot compared to the FF's.
Just my IMO but if you confirm any of them are causing issues its best to get the whole lot tested and cleaned Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253087 6th Apr 2014 3:38pm
paul271
I was speaking to a mate of mine who has a contact for getting them refurbed. Hopefully he's not too pricey. The plan will be to pull them all and get them done.
Post #253089 6th Apr 2014 3:55pm
Not FFRR but gives you the gist. I guess you can do one at a time til you find the one that fills the bottle?
Post #253090 6th Apr 2014 3:59pm
adigorn
whats the symptoms if i can ask
Post #253094 6th Apr 2014 4:25pm
paul271
It runs perfectly fine at all times but once it's up to temp if you stop and go to restart it turns forever and doesn't start. Eventually she'll catch and fire up again running perfectly.
It's as though there's just not quite enough pressure to get it going then once it's built up enough it goes.
Joe, thanks for that I'll have a watch.
Post #253105 6th Apr 2014 7:00pm
Next time try allowing the engine to fully prime a few times before cranking it and see if it helps.
Could also be a dodgey injector harness failing when warm and after a good amount of cranking contact resumes as normal.
Idealy you want a diag on it when its doing it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253109 6th Apr 2014 7:28pm
adigorn
defo fault reading is a must (and life data from low fuel pressure)
and leak off test recommended (my money on dogy injector)
harness would rather cause miss-fire than non start
Post #253112 6th Apr 2014 7:37pm
paul271
Cheers for the advice chaps. I think live data would be the way forward but my faultmate doesn't do live!
Am I correct in thinking that the engine would have to be up to temp for the injectors to fail whilst testing?
Post #253114 6th Apr 2014 7:44pm
adigorn
low fuel pressure to be checked just after ignition on (does not matter hot or cold)
injectors are more likely to misbehave when cold so easier to pick up the wrong one on cold-ish engine
faults you should be interested in
any fuel pressure related
Post #253115 6th Apr 2014 7:51pm
