![]() | Home > Technical (L322) > upper windscreen trim |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
from the pic it looks like its a push fit ,
| L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51
Thanks,
| Autobiography Member Since: 10 May 2011 Location: UK Posts: 926
Be careful with this piece of trim. You may need to remove the A Pillar trims to get a flush fit and the clips that hold these invariably snap in the process. I have had nightmares with windscreen trim following incompetent windscreen fitters who don't know what they're doing. Make sure it sits completely flush or you will be plagued with wind noise and vibrations! |
| mick-ne Member Since: 30 Nov 2013 Location: durham Posts: 133
Autobiography could you elaborate a little please. I recently had my screen cut out due to wind noise, sure enough the glass had parted company from the bonding glue however I still think the top of the screen suffers noise. Any ideas? |
| Glassman Member Since: 08 Apr 2014 Location: London Posts: 19
Technically speaking, the original trim should not have come out so easily. They're slotted onto the glass edge before the windscreen is fitted to the car; there is also a thin line of double sided tape inside the trim recess which helps keep it in place, preventing it from sliding left to right.
Thanks Glassman, looks like a hell of a job.
There should not be any bonding glue. I had this issue when the windscreen company tried to re-use broken trim clips by using glue. Correctly fitted, none of the windscreen trim should need any bonding. This includes top trim, a pillar covers and scuttle panel. Basically you need to watch them like a hawk to check they don't glue anything. Recently had a new windscreen fitted and I requested new trim clips etc from the outset. They are not reusable. |
Nobody is suggesting he should use any type of glue, and you're absolutely right.
| All times are GMT |
