![]() | Home > Technical (L322) > Speedo |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
Can't see it being the speed sensor on the wheel or the instrument pack would behave normally, but wrong - ie it would record mileage and average speed at 50 mph. Also the steering will be pretty heavy as the servotronic unit will think you are doing 50.
pete Member Since: 08 Apr 2014 Location: Bedfordshire Posts: 11 ![]() ![]() ![]() |
Hello Thanks for the reply
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
you cant go wrong in trying a battery disconnection, details are in the wiki.. ... - .- -.
Thanks I will give that a try I looked at several eart points and they looked ok but I will take them apart when I do a battery disconnect. I will check alternator first as well as reading your forum suggests they are very sensitive Electrically. |
I meant was the speedo working correctly before you send the instrument cluster away for repair.
Also, you can access the hidden BMW test menu by using the procedure below.
Thank you very much for your replys
Hi
I'd say the instrument cluster has failed the self test then, mine goes all the way around and then back again.
Just be aware, the dash binnacle is a one hit wonder... i.e. you cannot reprogram me it into another car once it has been programmed. |
Thanks for the replys
Ah, so you can't replace it with a unit from a scrapper, or even substitute it to aid fault finding ?
Ouch
Yes, unfortunately you VIN lock them when you programme them. So, no you cannot test it with another... |
