![]() | Home > Maintenance & Mods (L322) > Blueish smoke after idle tick over and no driving |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35746 ![]() ![]() |
what you said.. |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1230 ![]() ![]() ![]() |
Thanks for the reassurance Stan, I started her up again and there is no smoke at all now, so I think the recent throttling cleared it out. Always worrying when you see smoke, but seems normal on Diesels. Tom
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
Could it be turbo seals starting to let go, that would produce smoke like this? Current: TDV8 (3.6) RRS HSE
I'll keep an eye on it. The car has run for a couple of hours without moving or high revving so assume that it is a build up of diesel dust in the exhaust system, obviously it is not a common issue as most L322s will be driven. It is hard to rag it when it has limp mode on, but you can get the revs high enough to kick out a cloud, so hopefully it is just a build up over time.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I can leave mine ticking over from cold for @ 30 minutes to warm through and get no smoke.... but car does get a good rive every day. Not gloating, just alternative experience. .
