Home > Technical (L322) > 3,6tdv8 DPF ful Warning, any DIY tips or help?
Seabass
Sweden
Hi guys, my DPF ful warning light came on last night, searched the forum for info but did not find any info about this for the 3,6.
I know the book says go to dealer but is there any way to solve this myself?
My nearest LR shop is almost a days drive away, Is it dangerous to drive the car as is?
It's a 2010 with 90000km on the clock, only short trips has been made with the car the last month (15min)
Could this be the reason for not self cleaning the filter good enough?
Thanks Bow down 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Swedish LR club member #5333
Post #253909 11th Apr 2014 9:04pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Just had this on my 4.4 TDV8 caused by my "reduced performance" being driven for a couple of days and was told by a dealer the DPF regeneration procedure was 55mph or more for a minimum of 25 mins i.e. A good blast along a motorway!
I was also advised to do it asap after the dpf full message or its a trip to the dealer and more expense.
Post #253912 11th Apr 2014 9:27pm
Needs a good blast for at least 20-30 mins at motorway speeds to get it up to temp and burn off the deposits!
Dont keep driving it slowly! There is nothing that can't be fixed with a hammer😜😜
Post #253914 11th Apr 2014 9:41pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Hi,
I had a Jaguar S-type diesel some years ago, also fitted with DPF. Altough the DPF is a horror in my opinion it does give you an extra advantage above non ftted cars: you have to drive the car extra long/higher revs and it makes you happy in a Jaguar or a RR Razz
So to go short: yes you must regularly drive the car for some 20 mins on highway speed and than you shouldn't have any problems with DPF. In the event of a full DPF the Jag had first an orange light come on and that's when you can cure with the highway blast. If you ignored it then you get the red one and that's a hard fault which meant that it has to be regenerated by the dealer's computer. Don't now if a FF has the same two way warning system. But to avoid this: regularly drive it longer trips with higher revs (over 2200 RPM)!
How to now if the engine is regenerating? My Jaguar was a very smooth engine but when regenerating it was a bit rough on idle: never stop the engine in that occasion! The next time you start again the regeneration process starts from the beginning and that is a very bad thing. The regeneration is done by the computer by injecting a bit of extra fuel at the end of each firing stroke. This produces extra heat in the exhaust but at the cost of too much diluting the oil in the cylinders. So, when and if you can detect a regeneration process: never stop the car but go for an extra ride!
Good luck!
Post #253918 11th Apr 2014 9:56pm
Rangie4fun
To ad on this: you don't need to drive at higher speeds (altough it is the easyst way) because the revs is producing the extra needed heat. This means that you can drive easliy trough town for 20 mins or so but you MUST keep revs over 2200 RPM, this doing by using the manual shift option Mr. Green
Post #253952 12th Apr 2014 7:15am
Seabass
Sweden
Thanks gents, love this forum Thumbs Up Bow down 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #253966 12th Apr 2014 8:33am
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Another reason to go for a good V8 petrol, especially if you are doing a lot of short distances.
Post #253968 12th Apr 2014 8:45am
Seabass
Sweden
Took it for a 15min drive over 2200rpm and problem solved Thumbs Up 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #253989 12th Apr 2014 11:36am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Power of the forum again Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #253994 12th Apr 2014 11:50am
