Home > Technical (L322) > Duct Air Intake Manifold
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
4.4 TDV8
I have had a hairline crack diagnosed on the manifold. This is causing "restricted performance" to be activated.
Vehicle is 8 months out of warranty Big Cry so cost down to me no doubt. The manifold is on back order at Landrover till middle of May! Makes me think there may be an issue with the part.
It is a plastic part. Is there any way to temporarily cover/repair the crack whilst awaiting the new part? Running on restricted performance has also thrown up "DPF Full" so obviously won't be able to use the vehicle in the mean time.
Any ideas welcome
Post #253837 11th Apr 2014 1:08pm
Araldite. Thumbs Up
Post #253842 11th Apr 2014 2:10pm
Araldite won't last
Open out the hairline crack (just enough to allow it to be filled) and fill it with Q-Bond...sorted permanently Thumbs Up
I repaired a pinhole on a steel fuel tank a few years ago and it's still holding
Around £10-£11
Post #253847 11th Apr 2014 2:52pm
Of course Araldite will last for a temporary repair. Rolling Eyes Laughing
Post #253857 11th Apr 2014 3:40pm
Duct Tape around the thing Smile
TBH if they are on back order it could be due to demand for the engines in new vehicles, saying that thought TDV8 engines in 3.6 form seem to run low on stock a lot thanks to the SSRR boys Wink
If it were me and i had to stump up the bill i'd screw it and see if a metal one could be made up as it will no doubt crack again. Plastic is most certainly not fantastic for manifolds as the temps of a head are just way to much for them. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253870 11th Apr 2014 4:24pm
Araldiite = epoxy resin
Q-bond = epoxy resin + fillers
TBH a bit of duct tape is worth a try to see if a better repair is worth it 2008 MY Supercharged
Post #253951 12th Apr 2014 1:45am
^ Not strictly true.
Q Bond Product Description
"There are two parts included with this adhesive pack. It comes with 2 x 10ml bottles of quality cyanoacrylate glue that bonds to almost any surface forming a permanent bond in seconds. It also includes 2 x filling powders (1 in black for bumpers, grills, fairings and radiators; 1 in grey for aluminium, metal and grey plastic surfaces) that give instant reinforcement to the Q-Bond adhesive. These powders give Q-Bond the ability to be used as an exceptionally good repairing agent for cracks, holes and gaps in a range of materials from plastic electric boxes to metal engine parts."
Could be useful stuff though. Thumbs Up
Post #253963 12th Apr 2014 8:22am
OK its Super Glue and fillers , one thing I know from 20 years of boat building the quicker it sets the quicker it falls off Laughing .I was mealy musing that as Kingpleb said gaffer tape would give a quick idea if there was a feasible home fix . 2008 MY Supercharged
Post #253980 12th Apr 2014 10:00am
Post #253981 12th Apr 2014 10:03am
adigorn
Have seen 2 in the past year - so not too bad i guess have seem more fragile parts
if you keep running on "restricted" the damage to dpf might be beyond repair
and that will be the highest price you will pay
forget the duct tape idea (will not work due shape and pressures)
Post #253985 12th Apr 2014 10:30am
The Q-Bond will work Thumbs Up
One of the power steering cooler pipes on my Jaguar had a tiny rust spot that developed a weep (not enough to drip) and I sanded the pipe back to clean metal and applied some Q-Bond...sorted
If it can seal steel petrol tanks and oil coolers it will work on your manifold
Post #253990 12th Apr 2014 11:39am
Stocky
Thanks for the input guys.
Got a look at it and the split is right along part of a seam. To my mind that means it's a manufacturing fault. In any case, it's not in a place that can be easily temporarily repaired, especially given the pressures involved.
I spoke with LR CRC yesterday and sounds promising from their end, so had RR transported to a dealer for them to confirm diagnosis.
Then fingers crossed Bow down
I agree the running on reduced performance is the cause of DPF full, hence transporter.
Post #254109 12th Apr 2014 8:51pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
what was the outcome of this one? did you view the split whilst still on the vehicle without taking anything off, if so where was it? Cheers
James
Post #424043 20th Jan 2017 11:14pm
miggit
Whistle I used this on the plastic inlet manifold on my Mercedes, when I removed the swirl flaps... it's still there and withstanding major turbo pressure, which is more than can be said for the intercooler hose....that exploded the other week Sad
 Yesterday I couldn't spell Engineer... Today I are one!
Post #424055 21st Jan 2017 12:12am
JST
this is the only other ref to 4.4 intake split i can find, anyone else know of any? other than Buzzs! Cheers
James
Post #427931 15th Feb 2017 9:17pm
