![]() | Home > Technical (L322) > VentureCam problems |
Chriscase200 Member Since: 12 Aug 2010 Location: North West Posts: 9 ![]() ![]() ![]() |
Hi,
Thanks for the welcome!!
hi, thee are two versions of the venture cam that is the camera its self, as they seem to get lost may be some one has repaced it with the wrong one...check with your dealer on the part number. V8 facelift Range Rover Autobiography 22" wheels.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35795 ![]() ![]() |
like dave says, there's a 434 mhz and a 2.4 ghz version ..two different frequency's , you might have the wrong type... .. ... - .- -.
specman Member Since: 20 May 2010 Location: Fife Posts: 250 ![]() ![]() ![]() |
My Venturecam was completely dead when I got home having bought the car.
Thanks for the info gents. I know that the one I got through eBay is 433MHz because it said on the box. So I'll try to get hold of a 2.4GHz one to try that. It's going in to the dealer today anyway to sort out the mysterious engine management light with no fault code stored.
turn the original venturecam over and look at the numbers, see if they are the same as the numbers on your ebay one, if they are it is more likely you have been struck twice with bad luck. |
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
anyone ever used venture for anything at all ? i had designs on hooking it up as some kind of reversing cam (missing on my 05) but bothered.... |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Doublejay, I was told their most common use (except by dedicated off-roaders using it as intended) was by people towing horse boxes, as they put the venturecam in the horse box and could keep an eye on it from the car whilst driving along. Steve
or, you could use it to keep an eye on the kids in the back..
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I think Clarkson had the best idea for a use for them and for the surround cam system, but this is a family forum so I won't say what it was............................. |
