Home > Technical (L322) > Fuel Inject. System error message
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
hi gang , just got back of Holliday to north of Scotland in an Astra started off in the range rover till go to inverness when she decided to pack up ,displayed " Fuel Inject. System error message" on the display ,would not start .AA called and rangy recovered home ,me and Mrs in a Astra for three cramped days.
any way soon as got home put Hawkeye on and two faults come up as follows:
1260 fuel low pressure control
9f6 fuel pressure monitoring whilst starting
looked under bonnet and can see fuel and air bubbles in the clear pipe when key is in ign
any ideas?? 52 plate td6
regards pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254080 12th Apr 2014 7:35pm
Fuel pump?
Post #254083 12th Apr 2014 7:48pm
trainmanone
which pump?????
high press or in line or in tank?? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254086 12th Apr 2014 7:53pm
adigorn
In tank
Post #254096 12th Apr 2014 8:30pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
^x2 mine went at Xmas. The one in the floor doesn't display that message.
Post #254099 12th Apr 2014 8:34pm
trainmanone
ok so if pump in tank is kaput how come I can see fuel and air bubbles in the clear pipe near filter? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254114 12th Apr 2014 9:02pm
adigorn
cos remote pump is still working the thing is it should not burble but flow
Post #254133 12th Apr 2014 10:03pm
trainmanone
so how easy is it to change on a td6? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254138 12th Apr 2014 10:31pm
adigorn
piece of cake
back seat up carpet up replace pump
Post #254139 12th Apr 2014 10:36pm
trainmanone
well Censored me just gone out to rr and she started then cut out ,restated cut out difficult to start ,then all seams ok,starts on the button ,this now points where???????
think I might buy another omega Whistle Whistle Whistle
any ideas
Post #254244 13th Apr 2014 5:17pm
adigorn
to intank unit
Post #254261 13th Apr 2014 6:46pm
trainmanone
well just ordered both units of the bay for £80 need to strip down the sender unit down and fit pump ,will update when done.
delivery expected tues . have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254278 13th Apr 2014 8:59pm
trainmanone
theres a how to in the wiki for the 4.4 petrol is it the same setup as the td6?? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254579 15th Apr 2014 4:18pm
trainmanone
Censored Censored Censored Censored just broke fuel sender unit can I just buy the sender or do I have to get complete unit??? any body dot a spare one I can buy of them? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254584 15th Apr 2014 5:01pm
trainmanone
fitted new pump all back together pump runs ,and still wont start ,now where????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254969 18th Apr 2014 11:55am
