![]() | Home > General > Biggest fuel top up |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Oh Greg, that's not trying at all sir... There is something like 8 or 9 litres in the pipework too |
Greg66 Member Since: 11 Nov 2010 Location: London Posts: 84 ![]() ![]() |
110! I am impressed - at your nerves of steel! I might be prepared to try running it dry doing laps around the forecourt, but not otherwise.
Im sure they do sir yes... Mine needed a new tank pump hence the running it low |
Chauch Member Since: 09 Feb 2014 Location: Beds Posts: 303 ![]() ![]() ![]() |
The last owner claimed that he had run out in mine with 70 miles showing on the range so have been nervous of running it too low.
The FFRR has a tank capacity of 106 litres according to the handbook. Add in a bit for the various pipes, filter etc and probably 110 all told for a completely dry vehicle.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
the pump might have said 99.44 litres Gregg but can you be sure that was the amount that went in the tank.... ... - .- -.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
^ what are you insinuating Stan |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Bring back gallon cans to buy fuel in, not these new fangled pumps!! |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
I regularly pull in to the petrol station with only dashes on the range indicator...
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I've let it get pretty low at times. I'm 4 minutes from the US/Canada border and petrol is a LOT cheaper over there. Filling up in the States can be compared with LPG in the UK: much cheaper and the car still works. |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
Being a relative newbie I see I am also a bit chicken as I refill just below the quarter - my old p38 used to run out on the quarter the needle used to register full for a long time after a fill up though |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
i've learnt the hard way of not running the car that low - fuel pump in SA cost me R10k (GBP560) - after that i made (and is still doing that) of filling up when it reaches ¼ tank |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
I forgot to check most of the time but once I had it at 0 miles for about ten miles when I got it and it took 165 quid to fill to brim |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
I've often in my previous RR driven on 0 for more the than a few miles. Once or twice I've ran out of fuel, using just arriving home! |
