![]() | Home > Technical (L322) > Is this part of the towbar assembly or is it on all cars? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35876
i'm not sure but i think a crash bar has to be re-fitted when you take off the tow bar..hopefully someone will confirm or dispel this... ... - .- -.
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1042
Yep, you should have one or t’other
| Knightrider Member Since: 22 Mar 2014 Location: England Posts: 127
Was that a yep to my post or Stan's post? Which of those parts in the diagram is what I have taken a photo of? Also do I need a crash bar as suggested by Stan? 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
By the looks of it you have a Non OE tow bar fitted and you have only removed a portion of it. Then you would usually replace the original tow hooks... |
Hi here are pics of the tow bar parts removed from the car:
Definitely a non OE tow bar you have there sir... If you look at the pics RRPhil listed you can see the difference... You only need to remove the two side parts and replace the original tow eye bracket parts and you will be back to standard...
Ok bit of a snag there then as I have used that part to bolt my LPG filler cap to (as pictured).
Also does a crash bar need to be fitted? (mentioned by someone earlier in the messages) 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
| All times are GMT |
