Home > Technical (L322) > Fuel Inject. System error message
air block? ... - .- -.
Post #254974 18th Apr 2014 11:29am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
theres no fuel at filter. just fitted the pump under rear pass door
getting realy Censored off with this car now
help have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254975 18th Apr 2014 11:50am
adigorn
whats the low pressure reading?
Post #254987 18th Apr 2014 1:24pm
trainmanone
its reading 1.1 bar.with pipe off fuel filter and activating secondary pump wit hawk eye can hear it gurgling have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254988 18th Apr 2014 1:33pm
trainmanone
just noticed that I had said there was fuel at filter .....there isnt Embarassed have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254989 18th Apr 2014 1:35pm
adigorn
too low to get it started
from what i understand 2 new pumps fitted and both runing
measure low pressure with pipes on and ign on
(low sender is important as you need to have at least 30-40% of tank full to start it without)
not to repeat myself we need a fuel flow not bubbling or gurgling
Post #254990 18th Apr 2014 1:37pm
trainmanone
now im lost,,,, got just under quarter of a tank of fuel never let me down fuel wise befor?? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254991 18th Apr 2014 1:40pm
trainmanone
when I put my finger over the end of the pipe can feel pressure building up but just air coming out
any one near by can help me pls have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254994 18th Apr 2014 1:48pm
adigorn
have you wired intank pump correctly is it running?
Post #255003 18th Apr 2014 3:16pm
trainmanone
next port of call I think lol
defo not running going to have a look tomorrow now, just a thought does it have a separate fuse /relay for the in tank pump? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #255007 18th Apr 2014 3:57pm
trainmanone
Hi all just to update you all car now fixed. put more fuel in after replacing pump in tank and under pass side.
thanks to kingpleb for calling and offering his assistance
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #255427 21st Apr 2014 3:14pm
