Home > Technical (L322) > All i had left to do was a REMAP
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
After changing the Fuel and Air Filter, then the Thermostat all in a bid to squeeze a little more than the 21.9 Mpg i was getting Sad
Success Thumbs Up
it rose to 23.1 Mpg
next was the Remap
A friend of mine does this and he plugged her in to draw off the Files to see what was what
Ba Censored stirt there is already a Remap from Angel Tuning on Her already !!!
just wonder how the Standard was before that was done?
Can you run a Tuning Box in Tandem with a Remap - await all the Technical gurus on that one Bow down '54 Adriatic Blue Vogue
Post #255272 20th Apr 2014 12:58pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I would be surprised if you can run the two in tandem, surely a remap would require a change to the map that exists.
What a bonus though... 4.2 Supercharged Vogue SE
Post #255275 20th Apr 2014 1:11pm
You can but run the risk of A, smoking and B, going too far and exploding things Big Cry
Post #255290 20th Apr 2014 2:39pm
mjdronfield
I'd do one or the other if it was me.
No that's not right, if it was me, I'd only ever remap..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #255301 20th Apr 2014 4:22pm
Vogue
Bloody hell, run a remap and a box, even if it worked it is likely to blow the turbo - most remaps up the boost pressures and fuelling - I would stay well clear of the box. An engine that's lunched on a turbo is not a pretty sight Sad
Post #255338 20th Apr 2014 9:03pm
IMO the best thing you can do is get the GBox ECU remapped and blank off the egr and then clear out the inlet manifold from all the gunk thats been built up in it for 10years of recirculated dirty coked up air flowing into it.
IMO the gearbox is the biggest inhibitor to economy on a TD6 as below 50mph it is always slipping even if the TC tries to lock up its still slipping and wasting power.
When you sit on the motorway cruising at 50 or just over in a TD6 you can see it go past 30 and sometimes sit happily at 35 for a while. Even the TDV8's struggle to get a real world 30-35mpg so dont feel too bad.
If it matters that much flog it and get a 4.4v8 and LPG it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #255351 20th Apr 2014 11:03pm
A11EXU
Its not that being Scottish as you all think i am miserable
Yes we did invent copper wire by fighting over a 1p piece Razz
It is more of a challenge to get as much as i can with regards to MPG
My other car is a 944 S2 Cabriolet which is even worse than the FFRR but driven as if it is stolen with no regard for MPG, the environment, my carbon footprint or my Childrens Children (not old enough for the last one yet)
Thumbs Up '54 Adriatic Blue Vogue
Post #255353 20th Apr 2014 11:51pm
Vogue
If its mpg you want, you may have the wrong map, one of my old RR's a 2006 TD6 used to return a consistent 27 mpg driven hard - she was remapped by JE and would do 60 in under 10s.
Post #255362 21st Apr 2014 7:37am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Agree with the above - My TD6 (2004) was remapped - nothing else has been done - no EGR blanking etc and I get 24 round town 29-31 on a motorway run.
I asked for the middle remap - a bit more power but a bit more mpg so best of both worlds. It's no slouch now either.
I wouldn't go the "power box" route on top of a remap TBH Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #255364 21st Apr 2014 7:55am
A11EXU
Agree - will investigate the remap side and see if i am set for Power
done the EGR blank already
not driven many FFRR TD6's so don't really know if i am benefitting from extra Power - it is nippy but last car was a 525TD BMW E60 which ran a Tuning box and i also have a 944S2 Porsche Cabriolet so maybe the little extra weight is making it feel a little slow compared to my last Big 4X4 - Jeep Cherokee 4.0 Petrol High Output which was like sh Censored t off a shovel but only gave 18 Mpg on a good day '54 Adriatic Blue Vogue
Post #255372 21st Apr 2014 8:52am
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
mine has been remapped and i removed the cat plus egr blanked and kn filter ,i can get 30-32 0n a run no problem.
Post #255400 21st Apr 2014 1:11pm
