![]() | Home > Technical (L322) > [SOLVED] Trailer power sockets? (Towing Dunce!) |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
I have the OEM towbar.
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973
Aux power eg to caravan.
Thank you |
Also, if you don't seem to have any power coming from the white socket, check 20 amp Fuse 76 in the rear fusebox.
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
On a 2006MY SC F20 (20Amp)is the permanent supply & F1 (15Amp) is one of the switched supplies. I bought the 12 S adaptor from Martin & connected it up to my CTEK, no joy. Found that the 20 Amp fuse had blown and replaced it. CTEK seemed to spring into life. Checked later and found fuse had blown again |
| Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574
12N 12S pretty old hat now, and a cr |
| All times are GMT |
