![]() | Home > Technical (L322) > battery/alarm issues |
Do you have a towbar and electrics?
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Have you got towing electrics fitted?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
the side indicators take power when the ignition is off as the hazard lights can be used in this mode.. ... - .- -.
Take your point Stan, but if you don't have the hazard warning switch pressed, the lamp will still be open circuit. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
i dunno how it works Ray but others have used this method to slow charge the battery.. ... - .- -.
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
ok quick update - got a trailer socket that is wired up with a positive feed to number plate lights and an earth - connect it to a battery and all that happens is alarm goes off and remote fobs will not disarm the alarm or allow the doors to open. Any thoughts? getting worried now that will have to break in. Is there any other way to gain access without causing major damage? |
I still think you need to connect a battery charger to your car instead of a battery.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
If it is locked, I don't think that even if your break in (i.e. smash a window) you will be able to open the doors as they should be superlocked which locks out the unlock button etc.. There is a difference between knowing your sh!t and knowing you're sh!t
^+1 |
ok maybe needs left a bit longer - no lights flashing so battery must be absolutely goosed. That will get my own back on the neighbours......... |
whey hey finally got the door open............ |
Well done |
Aye - its jumped right to the very top of the 'to fix' list.......... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
A decent battery charger should be able to condition the battery and get it good again, though I understand you may not trust it now. Would give you a spare having fitted a new one, if that's the case.
