![]() | Home > Maintenance & Mods (L322) > change to led....start of |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1229 ![]() ![]() ![]() |
I agree with the drivers side being too cramped. I ended up having to crawl under the car to reach up and over the engine tray to recover the pesky fixing that dropped down. You have to creatively unscrew it and hold it into the screwthread to prevent it dropping by surprise, and just getting them to unscrew is an issue if they have not been removed in ages. However, once done it is a vast improvement and well worth the effort. Tom
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
I think the fogs are a lot easier to get to and there are lots of posts about modding to LEDs and LED rings. I just use the sidelights as DRLs and have kept my fogs as stock for when the mist rolls in. Tom
I have seen the posts about the rings and changing to led and white h7 bulbs, theres a loads of info on here, Im just wondering which way to jump at the moment.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35698 ![]() ![]() |
it'll cost you about £8 for a pair of 'white' type halogen bulbs so if you decide you dont like then you havnt lost much.. ... - .- -.
true, they are even changing our street lights to white leds and they make a big difference.. ... - .- -.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Only reason they are changing street lights to white LED is running costs - PAR 38 lamp (yellow sodium) 38 Watts, LED array 6 Watts, therefore 80 odd % cost saving |
