![]() | Home > General > Faulty suspension query |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Could be a number of things but most likely is a failed air suspension pump not delivering any air to the reservior. They can be refurbished at home aparently and there are a few on here who have done it using the following kit
For another few quid you could get one on an 06 although it's petrol
chawks Member Since: 28 Oct 2013 Location: Dorset Posts: 309 ![]() ![]() ![]() |
Well that's the other option - get a V8 and LPG it. I do like the V8s and have had an lpg one in the past. However the mileage on that one puts me off a bit. But for that money can't be bad. |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 ![]() ![]() |
The faults on that one sound just like mine. I had the suspension pressure static when filling and bought a repair kit for my compressor for £180 but it made no difference so then had to buy a new one from paddocks for £300. I know a lot of people have been lucky with the compressor repairs but this time I was not. The screen being blank on mine happens every so often but comes back on when it feels like but that's no real problem as mine has the original sat nag disk in so is pretty useless compaired to up to date ones so don't use it. The heated seat not working seems costly to fix as the heating units are sewn into the leather seat cover and a new one is required, I think some one on here has tried to fit a newer heated seat pad bt not sure of the out come.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
What would worry me is no service book. Not a real problem if it's got a big wedge of receipts and invoices for past work done on it but no service book suggests an uncaring owner. A list of faults also suggests it being run on a shoestring, £200 off for a potential £300 compressor replacement and that's just parts cost, no fitting?
I was put off by the no service history for the same reasons as you have just said, so I didn't bother looking at it. A TD6 03 plate just been advertised locally for similar price but that is an SE spec and has 145k miles - but lots of history. Might pop along to have a look around it. Think I'd rather buying something older/ cheaper that has the big works done (transmission etc) and have some in reserve for any other niggly things that may or may not need. I never seem to be able to find the £4.5k bargains that one member on here found |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Very occasionally someone will find a real,genuine bargain |
