![]() | Home > Technical (L322) > Alarm going off |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Try putting a blob of chewing gum on the top of the switch plunger, close the bonnet and see what happens. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
disconnect the switch and put the 2 wires together...... ... - .- -.
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
This happened to me, ibuilt up the top of the plunger with double sided tape cut into small squares, problem sorted 07 Vogue SE Java Black 3.6 TDV8
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi CSK and this is a common problem.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
^ I think he meant 'make sure you CLEAN the surface....' |
Thanks Fill Fat Ray, and post corrected. 2007 TDV8 Lux |
You need a new 'smell checker' sir!!
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Hi guys, I hadn't had the time to thank you yet, busy day! I've put a piece of self-adhesive plastic under the bonnet right above the button and fingers crossed I haven't had a false alarm today. |
