Home > In Car Electronics (L322) > antennae for digital hybrid
kirton
England 2006 Range Rover Autobiography 4.4 V8 Zermatt Silver
This conversion is as clear as mud to me. From the way I see it. I can replace the analogue factory fitted tv tuner in my 2006 model with RSE with a Jaguar hybrid. Part numbers are noted from other threads.
My question is, can i use the same antennae in my rear side windows or must I get something else. If I do have to replace the antennae does anyone have a recommendation?
Question
Post #257056 30th Apr 2014 7:45pm
same antennas i believe...mine has digital and the windows look the same as the windows on my old td6 .. ... - .- -.
Post #257060 30th Apr 2014 7:49pm
Discotigger
The antennas are the same, the hybrid digital tv unit is plug and play. The touchscreen Denso satnavs systems are all compatible with the hybrid tv units, but make sure you get the tv units with the correct part numbers. There are some hybrid units advertised on fleabay which aren't european spec. and they don't work.
Any hybrid tv unit with the part nos starting AH42-19C063-xx should work (the -xx suffix will be Alphabetic numbers, e.g. AA, AB, AC, etc.)
Post #257109 30th Apr 2014 10:28pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I just swapped connector from the old analogue box to the hybrid box that sits next to it and all works, 2 minute job, aerials etc all the same There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #257170 1st May 2014 10:21am
kirton
Thanks guys, that is all very helpful. I was finding some of the other threads a bit confusing. I have bought a 2006 Autobiography with RSE and it it seemed a real shame not to keep it up to scratch. Very Happy
Post #257265 1st May 2014 8:03pm
