Home > Maintenance & Mods (L322) > Non starting |
Ours lost power on the motorway a month ago and the reduced engine performance light came on. MD later told me that they plugged the diagnostic tool into the car and the reason for the reduced engine performance was because the water pump (connected to the supercharger I think/ mechanic said it was a known issue on the SC) had failed. They replaced the water pump. Don't know if your car will have similar?
3rd May 2014 5:42am |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 |
Got a fault code reader and its not listing any fault codes at all and there were absolutely no warning lights came up on the dash at all. Hoping a new fuel filter will resolve it and read on another post that giving the fuel pump a knock with a hammer can sometimes help. Hope the rain stays away today............. least till its fixed. |
3rd May 2014 9:03am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
Do you get fuel through the pipes to the fuel filter with the ignition on ?
3rd May 2014 9:11am |
ok - new fuel filter installed and not made a jot of difference (only filter that not been changed since I got the car so was on the list of to do's. After a bit of further investigation on fuses/relays we have arrived at 12volts getting to the fuel pump ok but pump is not working so appears pump is the issue. Anyone any experience with reviving a dodgy pump or am I best just to replace it? |
3rd May 2014 5:21pm |
I take it you mean the inline pump ? Not the one in the tank ?
3rd May 2014 5:24pm |
Its the in tank pump - the 4.4 v8 only appears to have one fuel pump, got really confused looking for a 2nd pump but there isnt one - not according to the manual anyway. The part that you access underneath the vehicle on passenger side thru the small panel is the fuel filter. |
3rd May 2014 5:54pm |
Ah, sorry chap. I wasn't sure what the petrol rr had, no experience of the in tank pump I'm afraid.
3rd May 2014 5:59pm |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 |
there is a how to in the wiki ....... of a job,new pump/sender best part of £300 ,or can get pump only for £39 on the bay have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
3rd May 2014 7:10pm |
yep found that - great to have the instructions - not looking forward to doing it but got to be done. |
3rd May 2014 10:48pm |
mine packed up not far from you a few weeks back,she had a nice ride back to stockport care of the AA have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
4th May 2014 10:20am |
