![]() | Home > Technical (L322) > How long before gearbox fails again (after temp fix). |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
The aluminium filings in the oil indicate the torque convertor lock-up clutch friction plate is seriously worn allowing metal to metal contact in the clutch. As a minimum you need a new/re-manufactured torque convertor fitted. The aluminium filings also block the oilways in the oil cooler resulting in reduced oil flow thro it with the oil running hot and degrading. You really need to change the oil cooler.
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1236 ![]() ![]() ![]() |
The autobox mechanic agreed that the whole thing ideally needs to be changed including oil cooler. He has done quite a few L322s and seems to know his stuff.
135k is pretty good, I think it's fair to say you've had your monies worth. |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
Correct, the oilcooler is also after flushing full of metal parts, only the pipes you can flush. Best way is a complete renew of the gearbox, in the time, when the box is out, and at the recon Company, you have enough time to buildt out the oilcooler, (difficult to reach, and be carefull with the three screws), NEW!! oilcooler good prices in Internet, and after Fitting the new cooler and the flushed pipes, it is easy Job to install the box..., best wishes from Germany (third box in 212.000km) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
I picked the car up today to get it MOT'd and taxed and had another good chat with the mechanic. He also recommended the Dr Tranny (or similar anti shudder additive) and said he puts some in the torque converter when putting together a complete rebuild on all his jobs.
