Home > Maintenance & Mods (L322) > Blown front air spring do I have to change them both?
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
As it says in the title one of my front air springs has just popped and I just wondered do I have to change both sides ?
Post #258238 8th May 2014 2:04pm
you dont have to but the other side will be 'as' worn as your blown one so it would make sense to do the both.. .. ... - .- -.
Post #258241 8th May 2014 2:11pm
birchyman71
That was my thoughts aswell but thought I'd ask I've ordered both sides Dunlop ones with bolts £430 with next day delivery comes after brake pipe popped on Monday and mot is due end of month , looks like it's beans on toast til next pay day
Post #258245 8th May 2014 2:29pm
i thought beans on toast was a daily dinner for us FF owners.. Laughing ... - .- -.
Post #258247 8th May 2014 2:32pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
As has been said it's advisable to replace both at the same time unless one has failed soon after replacing. The front strut also contains the damper so if not changed in pairs could lead to wayward handling plus the reason of airbag wear mentioned by Stan above.
I've just changed mine for Delphi items (as per OEM) after one split, weird thing was it would still keep it's standard ride height fine but couldn't get to off road height as the split would open up. It must have been like that awhile, I only noticed when it was parked at an odd angle and air was peeing out because it was trying to compensate.
Very easy job to change (well with an impact gun it was!).
I was even more impressed when cleaning the old label to discover they were the original struts, 12 years and 103k miles is pretty good going I think!
Post #258275 8th May 2014 4:04pm
Also, the Dunlops do not come highly recommended on the forum, many early failures reported. Get the Delphis. .
Post #258289 8th May 2014 5:47pm
mjdronfield
I agree with Joe90..... I put a pair of Delphi units on over a year ago, after reading about some issues with the Dunlops.
Never had an issue.....
Got mine from Dan at Duckworths.
Excellent service.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #258297 8th May 2014 6:33pm
ebajema
I replaced them both on my 4.2 and they were both similarly worn (normally you couldn't see it but once of the car and the bags blown up it was crack fest). Both Delphi (only option for the SCs anyway) from Island 4x4 who had the best price at the time. Plus they arranged delivery to Nigeria without any hassle.
Always do both as indeed the shock is part of the strut, so you are also replacing the shocks at the same time and both should be in similar condition i.e. new or similarly worn.
You can also get the airbags (well via the US) themselves and replace those. Lot more work but doable (from what I saw on the YouTube clips) and cheaper. Trick is get the correct bags of course or the good quality bags. Rangerovers.net may be helpful with the bag replacement only option. MY 2010 5.0 SC Galway green and sand interior!!
Post #258337 8th May 2014 11:13pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
I did both of mine with the dunlops and I've had no problems.
Post #258339 8th May 2014 11:27pm
ebajema
Not all of the Dunlops are bad, just that there are a few people on here that had to replace them very shortly after the new ones went in. If I remember correctly the issue was the top bearing failing. MY 2010 5.0 SC Galway green and sand interior!!
Post #258340 8th May 2014 11:33pm
mjdronfield
I seem to remember something about the Dunlops sometimes making a clunking noise over bumps / when cornering.
Delphis are a similar price.......not much in it. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #258362 9th May 2014 7:55am
birchyman71
They arrived yesterday and due to people's posts about the top bearing on the dunlops , had a good look at them and they appear to be ok , it's tomorrow's job so hope the rain holds off .
Post #258590 10th May 2014 12:32pm
ebajema
I suggest to make sure the top bearings are well greased if not sealed. To prevent potential issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #258598 10th May 2014 2:33pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
@birchyman71, it is not only grease in the top, it is the bad quality of the bearings. Save your bill, and if there is some knock-knock after some months, you can bring them back (I did so, first ordered Dunlops at island4x4, after nine month full waste, ordered some Delphi, difference price was 50 GBP, only the 50 I had to pay, the old dunlops they dont want to deliver back, so I could open them and had a closer look in the bearings...) Best wishes!!! Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #258626 10th May 2014 5:56pm
birchyman71
done them today ,drivers side was original dated 2002 ,passenger one was 2006 ,took about 2 hours all together ,going to get the alignment checked tomorrow sometime just to make sure I haven't disturbed it . test drove it no clunks or bangs so will wait and see and as I've been warned I'll be keeping the invoice just incase. On a good note the movement times from access /normal /offroad have easily halved.
Post #258796 11th May 2014 7:33pm
