Home > Technical (L322) > Which transfer box?
Which transfer box?
Does anyone know What transfer box is in the 2006-2009 tdv8?
Im trying to do a bit of research on it before it goes into the garage to have it resealed for the 3rd time!
I can find info that the 2002-2006 is an NVG unit but this seems to be different from the latter cars.
Cheers
[/i] There is nothing that can't be fixed with a hammer😜😜
Post #258546 10th May 2014 8:38am
Found this which answers ^ that!
http://www.fullfatrr.com/forum/topic12404.html
Does anyone know what the best rtv silicone is for making the gasket, as this is what keeps failing! There is nothing that can't be fixed with a hammer😜😜
Post #258548 10th May 2014 8:52am
wealy
are you still having trouble
mine has started leaking again.
Post #259384 14th May 2014 2:26pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
These tdv8 RR seem very problematic as much as td6 I think I'm going to hold up on a newer model Sad _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #259386 14th May 2014 3:27pm
wealy
I'm told by the garage that it looks porous - has anyone heard of this?
Post #259390 14th May 2014 4:30pm
Nope, never heard of the casting going porous, i will get them to check it out while its out, im going to ring a tranny specialist tomorrow to find out the gen on the box.
Half thinking of seeing if i can an exchange recon unit and just replacing the whole thing. Pretty sure mine isnt porous as it was fine for 3 months minimum, as it was done in december and i checked it march time. Only noticed it cos the mids got a ball under the car, so it started leaking between march and now. Its going in on 20th and they will drop it out again and reseal it but if its has gone porous, which i have some doubts, then it will be a new one.
This is the last time this one is being sealed, next time will be a new one. There is nothing that can't be fixed with a hammer😜😜
Post #259450 14th May 2014 11:13pm
wealy
How did you get on?
Post #260525 20th May 2014 4:52pm
Been in today and they replaced the hi/low position sensor as it was leaking from the block connector aparently, anyhow i will check it in a couple of days to see if it has stopped leaking.
They also replaced a split cv boot for good measure as well. So now should be perfect for a few days at least!
Inam fairly convinced that this might have been the problem all along. There is nothing that can't be fixed with a hammer😜😜
Post #260760 21st May 2014 9:04pm
wealy
Hi mark
Is that the unit on the passenger side? Do you have a picture of the old one or what it looks like?
Post #260783 21st May 2014 10:18pm
The above pic is taken from the rear looking forwards, so yes they are on the passenger side, The little black module is the hi low sensor and it is tucked up towards the top of the box, the unit below left is the motor they changed the little black unit. I am going to run it for a bit and see if it has sorted the problem! There is nothing that can't be fixed with a hammer😜😜
Post #260832 22nd May 2014 7:48am
wealy
I've had another look under mine and I really can't see where its coming from.
It collects on the cage thing and drips on the garage floor.
Its a mystery???????
Post #260943 22nd May 2014 1:57pm
wealy
i Mark.
Is yours OK now?
Mine seems to be weeping from the shift motor end cap?
Post #262465 31st May 2014 3:42pm
