![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Here is a pic of the boxes my bulbs came in. Shows make etc ;
| psgk Member Since: 18 May 2011 Location: Chelmsford, Essex, United Kingdom Posts: 48
Yes, the boxes and info are identical to those I received. If my bulbs didn't have that small nib at the top of the glass envelope left when they are manufactured they would fit as I think that couple of extra mm would make all the difference.
| trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46
Glad to tell you all brightness of reverse lights is not an issue as they are not part of the MOT !. Same as front fogs . |
| GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836
Tried to fit mine last night and failed. The problem is the upgrade bulbs have offset pins at approx. ten to two position, compared to the original bulbs which have the pins opposite each other (quarter to three position)
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
this might help if you order replacements,
So this may explain why some have issues ? Do the later cars use straight pins perhaps ?
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Could you not file the lower mounted of the bayonet pins down with a file so as to get round the pin offset problems but still leaving the upper bayonet pin unscathed to ensure a good fit (did that with LED bulbs and it worked perfectly well)? |
@A11EXU, have you managed to do any daytime pics of your COBS? ... - .- -.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I received mine and like some mine will accept either type of bulb... I too had the length issue (ooh err) so i simply cut some material off the plastic locking pins on the side of the bulb holders using a craft knife. I then simply put an extra rubber "O" ring on to space the light back and hay presto |
| RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186
Very clever Craig |
Hello Craig,
Taking a mm or 2 off the tabs mean your bulb will fit a mm or 2 further from the lens and you run less risk melting the lens |
Many thanks Craig, an excellent explanation which is much appreciated. Peter Kemp
