Home > In Car Electronics (L322) > 2003 Vogue Modifications/Upgrades Advice please.
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Hello All,
First time RR Vogue owner and new to the site.
I have bought a 2003 Vogue, fitted with the non touch screen Sat Nav/TV screen. I have scoured the forums for help on how to fit a reversing camera to the system but it just leaves me even more confused as to what I need and where/how to wire it.
Can anyone who has done this please tell me what they bought and how they wired the system up.
Also, I am guessing that the TV tuner fitted only receives the old analogue signal. Has anyone fitted a digital receiver? what system did you buy and how did you fit it?
I am sure that all the answers are buried within the forum but i am finding it difficult to extract the information I need.
Sorry if I am being thick.
Post #258721 11th May 2014 11:33am
This thread "may" be a good place to start to help understand the wiring
http://www.fullfatrr.com/forum/topic8786.html
For reversing camera, there is nowhere to install it, you will have to find a location - drill hole, fixing below bumper, number plate light etc. Wiring to TV module not too bad, then connecting up the gear lever to the grounding wire (so cam comes on when you go into reverse). You may need a link cable in order to do all this.
You can get a hybrid receiver for @ £300 on ebay (supposedly straight swap) or you can get Baris (on forum - TV/Radio module guru and fixer) to convert your existing, or there are other third party add ons for this .
Post #258726 11th May 2014 11:46am
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
i have just undertaken the exact same job
very easy if following the instructions on said previous thread.
Confused although have to admit it is not working 100% and is "pulsing on and off in reverse" as if it is either losing power to camera or losing signal to change to Camera input on Front display - a relay problem ??? '54 Adriatic Blue Vogue
Post #258735 11th May 2014 12:55pm
iphs
Thanks for that fellas. More confused than ever now with all the talk of PC, PS1, iBus and all the other terms used in there.
Might just give this a miss. Only wanted a camera to help with caravan hook-up. I have this on my Sorento and it works a treat.
Ian
Post #258748 11th May 2014 2:26pm
You could always do the two phone webcam thing, useful for occasional use.
In simple terms, one smartphone with suction mount fitted to rear of car, one smartphone in cradle up front by driver.
Install suitable software depending on your phone type for transmitting camera capture at rear to camera viewer at front.
It is on here somewhere....
Job done .
Post #258754 11th May 2014 3:35pm
iphs
Thanks for that.
I think I will just go back to the old and trusted method. Let the wife stand in the rain and give me dodgy directions.
Regards
Post #258757 11th May 2014 4:08pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
You Know it makes sense Rolling with laughter Rolling with laughter 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #258768 11th May 2014 5:08pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
You can get Wi-Fi cameras too just to add complication. Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #258771 11th May 2014 5:22pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
http://www.ebay.co.uk/itm/Anti-fog-Waterpr...1c35ae5635
this is the type of reversing cam i fitted to the non touch screen nav screen(pal not NSTC as this one)
used the diagrams below for my preferred instillation
you can buy the fly leads from BMW to fit in the tv modual plugs (think you may need 5 if i remember correctly)
about £1.50 each
fitted my cam by the side of the number plate light so it gives a perfect view of the tow ball to assist hooking up the trailer
ill post some more picks tomorrow
lots of posts on the BMW forums about reversing cams
[img]http://www.fullfatrr.com/gallery/albums/userpics/14187/backup_camera~1.pdf[/img]
Post #258821 11th May 2014 9:08pm
kiter
Did the TV upgrade - bought a hybrid unit from a BMW X5 - take out the old and plug in the new one and job done (mind you first one I was sent was faulty and came from latvia, but true to his word seller sent me a replacement as promised that has been fine). Other upgrade I did was replaced the CD based sat nav for the newer DVD version - again plug and play all done in 2 mins, still not the best but so much better than the CD based one.
Post #258857 11th May 2014 10:12pm
Nice work and instructions ironhorse Bow down Bow down Bow down
Did you enjoy working the video cable from the number plate area back to the tv module as much as I did? Smile .
Post #258871 11th May 2014 11:07pm
mjdronfield
I started this BMW upgrades thread a couple of years ago ;
http://www.fullfatrr.com/forum/topic9811.h...w+upgrades
Has more thoughts and details.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #258901 12th May 2014 8:50am
ironhorse
Joe90 wrote:
Nice work ............
Cheers Joe I know your pain there
Lol
Getting the wiring through the rubber cable cover from the top of the upper tailgate to the body was the best bit,think KY jelly was the answer I seem to remember
Nige
Post #258917 12th May 2014 9:46am
ironhorse
reversing can position
cam looking at towbar
i have changed head unit but this was working on the OME non touch screen with diagrams above
Post #259091 12th May 2014 9:57pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I wish the proper camera was there so you could actually see the back of the FF. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #259093 12th May 2014 10:05pm
