![]() | Home > Technical (L322) > TD6 started reversing while “D” was engaged |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
For starters you need to check your gear selector is tight and well greased (this is under the car offside/right side gearbox). If all OK there lift the gear lever panel surround and check all is connected properly there. More likely to be mechanical than electronic, though you never know.....
clarkie Member Since: 26 Aug 2013 Location: leicester Posts: 51 ![]() ![]() ![]() |
the car should not start at all if a gear is selected,only with park or nutral selected should the car start, |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
In my old RR Classic I had the accelerator cable get stuck in the engine bay resulting in the car trying to drive off when my foot was on the brake but I think the L322 is now all electrical. I have never heard of a Range Rover gearbox changing from forward to reverse gear though. Tom
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7920 ![]() ![]() ![]() |
As Joe90 suggests, check the linkage on the side of the gearbox. Needs lubricating ?
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 38 ![]() ![]() ![]() |
Thanks for the tips! Especially on the cable. Will check this later on.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
New one to me! |
Yep, something wrong if it will start in gear |
Definitely should not start in gear. Maybe when they did the rebuild the sensor or selector cog was not calibrated or connected back properly. Tom
So one more feature to test prior to buying a FFRR |
AS said above the CAR SHOULD NOT START OR ENGINE TURNOVER with the Gear Selector in anything but Park |
I paid a visit to an indie in Tallinn. They did confirm that there is a problem (surprise!) but it can't be resolved with a diagnostic tool. Asked me to call back on Monday as they need to do some research. The problem is almost certainly in the electronics but can't say for sure.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1003 ![]() ![]() |
You would have to by-pass the inhibitor switch in the sump
According to the garage in Tallinn, the problem appears to be located in the speedo/cluster/instrument binnacle. The garage was able to gather all sorts of data with the diagnostics from the speedo, except in which position the gear selector was. The correct engaged gear does light up in the cluster, but the speedo does not "understand" the position. So the gear indicator provides the info only for the driver. The diagnostics tool can read from the speedo, when the parking brake is engaged. There were no other problems. My own conclusion is that the reversing issue was most likely caused by the cable, but I will look at that later on.
The cluster is a VIN locked unit and can't (to my knowledge) be reprogrammed to another vehicle... So, your only choice would be a new unit if yours is un-repairable...
