![]() | Home > Maintenance & Mods (L322) > Anyone tried these? Led Fog Lights |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
These look v similar to the ones stan has. Anyone have them? Do u think they just plug and play ?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35762 ![]() ![]() |
paulmoron2 has them,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
paulmoran2 ! |
Highly rated by cannabis growers |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Lolo..I have Pm'd you with some info |
Mike.Boro Member Since: 09 Dec 2013 Location: Middlesbrough Posts: 44 ![]() ![]() ![]() |
I fitted these to my 2002/2010 conversion. Had to fit H11 resistors. They are the correct size and brackets are right, look the part. 10 mins to fit |
Yes, if your using them in lieu of standard bulb fogs, the canbus (bulb failure) warning would appear on your instrument cluster display unless you switch off hot and cold monitoring using an IID tool ( or similar ) or have a ballast resister in place.
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Has anyone tried putting these fogs onto a <2010 model? If they are the same size as the pre-facelift they should work no? |
i have these, produced by craig [cam-tec]
Horse86.
Thanks Stan and Paul. Very cool. Those look a lot like the ones for the 2010+.
http://www.fullfatrr.com/forum/topic22046....fog+lights
thanks for the link! |
