Home > Technical (L322) > 'Check coolant' msg after replacing header tank
Texel
2002 Range Rover HSE 4.4 V8 Baltic Blue
Morning all,
Found the header/overflow tank on my 2002 4.4 has the tiniests of cracks in one of the plastic seams and was ejecting steam and water out of it, actually took me a while to find it and thought I had a head gasket drama unfolding, as I could never find coolant on the ground.
Anyhoo, found a new tank, put it in (I'm liking the hose quick detach feature) and topped everything up as best I could.
Now I still have the 'check coolant' msg on the dash, even though the floating doodad is showing the correct level.
Even after driving and the msg goes away, it still has two LED type arrows pointing in from either end of the display, which I'm sure weren't there before (but the might have been, just can't remember)
So the Q is: does the warning have to be reset by someone with the gear? or have I got an airlock somewhere that has to be sorted.
Thanks for any advice
PS: got the neighbour to have a look, but that was a waste of time, she doesn't know jack about the later model ones
Post #258939 12th May 2014 10:25am
ebajema
What coolant are you using? And is the cable plugged in properly? MY 2010 5.0 SC Galway green and sand interior!!
Post #258992 12th May 2014 2:45pm
mjdronfield
The arrows are to indicate you have a warning message that you have read, but is still valid.
Or more than one message and you have not read them all
If you fix the issue, it will go away.
It will check level, and then the level if antifreeze in it, so if it's the right level but not enough antifreeze, the message will come up.
Check for air leaks by having the heater on highest setting and let it tick over with the cap off.
Water should complete the circuit when the air is out and the thermostat open....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #258993 12th May 2014 3:01pm
Texel
Thanks for the replies, will do the open cap trick in the weekend and report back.
Coolant is green, will find the container and see what make it is.
The wee sender thing in the bottom of the tank seemed different to the original, put in the new one first, and then changed back to the original after the fault message but that didn't improve the situation.
Will post some pics of the new sender unit which has very tight shrink wrap over its top end, as the two water sensor bits seemed to be exposed to fluid I left the wrap in place, not too sure about that part.
Will also section the old tank to better understand how the sensor works, pics to follow but probably not until the weekend.
A problem shared is a problem halved!!!
Cheers
Post #259170 13th May 2014 10:58am
mjdronfield
That just made me smile.....a problem shared is a problem 2 people have Rolling with laughter
I was going to suggest you look at an IID Tool for fault diagnosis, but I think I prefer your neighbour.
Though not liable to help diagnose this one. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259175 13th May 2014 11:02am
Laughing ... - .- -.
Post #259176 13th May 2014 11:04am
Mine had a new rad just before I bought it, well it looks pretty new...
Checked mine the other day and found that it's just got water in there, totally clear and no taste to it!!!
I've stuck some rad flush in it and am going to sort it at the weekend and change the top hose...
Mine never came up with a warning light to say it didn't have anti freeze...
Or is that feature just on the later ones??
Cheers.. Pete
-Click here for Thread-
Post #259183 13th May 2014 11:51am
mjdronfield
Seems strange. Think yours should work the same as mine Pete.
That said, mine only complained once about the mixture when I test drove it, and dealer had to fit a new rad....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #259189 13th May 2014 12:01pm
Does seem strange, never mind, five year coolant and distilled water going in at the weekend after a good flush... Pete
Post #259193 13th May 2014 12:08pm
Texel
Me again.
Cut open the header tank to have a look.
Interestingly the blue sender unit doesn't get in contact with the coolant, seems that the white float has a ring magnet in it that moves up and down and that magnetic current tells the sender what the level is.
I ended up putting the new sender back in after taking off the plastic shield on, don't do that, it holds various skinny bits of wire and some sort of resistor in place, anyway it didn't work first time round and still no go.
My replacement tank was a bearmach, and the sender style is a little different so will hunt out a blue one like the original.
One thing I did notice that is that the sputnik type thing on the top of the float can sieze in place with dry gunk (if the tank was allowed to sit around empty) and I imagine the float wouldn't be going anywhere after that.
Will get a mate who is better with electricity than I an to test the senders and see if putting a magnet around the pole makes them pass current
Cheers
Post #260013 18th May 2014 5:35am
