Home > Technical (L322) > 2006MY TD6 Battery Drain
javablacktd6
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi Guys
Hope someone in the know can help me with this age old L322 topic.
I have a 2006 TD6 Vogue
If I drive the car every single day the car will restart fine the next, if I go a day without driving the car, as you do, it will not have enough battery power to turn over
There are many topics involving changing the air con final resistor unit, and also the now obsolete YNI500040k WIRING KIT to stop the tiny fan running on behind the little grill on the hevac panel.
there is also a lot of mention with this affecting 2004MY cars and certain chassis ranges
My question is I have a 6A car 2006MY. Were these faults still relevant to my late model year car?
I can here the little fan grating away behind the dash when I listen down by the clock but haven't monitored how long it stays on for yet as I have heard that even opening the doors to the car activates this device, and many saying it wouldn't have enough in it to drain a battery to that extent anyway.
Can anyone shed any light as to wether this is still relevant on a 2006MY car as it seems changing the hedgehog near the footwell does not often remedy battery drain issues but changing the now obsolete harness cures the problem along with replacement relays? Which does not help me if I can no longer purchase the fix for my car and im certainly not forking out for a new hevac unit at many hundreds of pounds when I may be looking in the completely wrong area?
Post #258336 8th May 2014 11:00pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Knowing what I know now, if this was me I would do the following first:
1) get battery checked by someone who has proper battery testing equipment (ideally someone who's not just going to try and flog you another battery!)
2) a current draw test
Because either the battery is shot or current is being drawn whilst your asleep!
My 2p is not to spend any money on any other stuff until you've done the above...... 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #258341 8th May 2014 11:42pm
SKOT
Oh and I can talk on this subject with some authority. I bought a new LR battery for my previous TD6, still got starting problems if left more than 2 days. Replaced all sorts including the "hedgehog" and it turned out to be my NEW battery was faulty. Very annoying! Twisted Evil 2006 4.2 SC
Post #258342 8th May 2014 11:47pm
javablacktd6
Thank you Skot, I will get that done. The Censored thing goes flat every day now wether Im using it or not so seems to be either a bettery or one hell of a drain!
Post #259291 13th May 2014 10:52pm
SKOT
Well a drain is unlikely (although not impossible) to get worse.
I bet it's the battery on its way.....
Let us know how you get on. 2006 4.2 SC
Post #259294 13th May 2014 10:55pm
