![]() | Home > Maintenance & Mods (L322) > Battery issue - MY11 - dealer can't figure out what it is |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 508 ![]() ![]() ![]() |
Hi all,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Is there a battery software update for your car? .
Thanks both. No tracker, and because its the first time this has happened doubt they will replace the battery under warranty. In any case battery itself is not covered by LR extended warranty.
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
Hi, I had the very same problem with my 12 tdv8. After a few months of use I left the vehicle in a marina for 7 days and when returning, same complete drain was observed what you described. Jump started and took to LR dealer. They identified a completely drained and short circuited battery. After a short argument they agreed the replace the battery with original LR AGM battery made by Exige. Since then - for the last 11 months - issue has not repeated. Have left the vehicle for a week since and started without hesitation. Although I got a good charger and recharge, condition the battery regularly.
quick update as I got the car back today...
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2620 ![]() ![]() |
Also had the adhesive fail on that foam piece that closes off the underwing/door jamb hole. Twice. Seems to be absorbent so was soaking wet. |
^ totally agree - I could have washed the car with that much water... can't say I should be surprised though... MY11 Vogue 4.4 TDV8 - "African Queen" |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 745 ![]() ![]() ![]() |
Shaltz do you have the AGM battery fitted to you vehicle ? early 2011's including mine were recalled for a battery swap and a software update. 2021 P400 Silicon Silver AB
The dealer said it does and I have an invoice from March 2011 saying the battery was replaced with AGM (car was with previous owner at the time)..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Was it left at an airport??
interesting - I never knew that about airports...
Know you're out of warranty on the battery Shalz but thought I'd add this:
