Home > Maintenance & Mods (L322) > Are there any air suspension bag maintenance options?
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I was wondering if there are any coatings or treatments that would help extend the length of the air suspension bags and help delay them drying out and cracking over time?
At the moment I just keep them clean with a good jet of water, but as with the door seals you can get silicon grease etc to help soften the rubber. Would something similar work on the bags?
I also wonder if it is better for the rubber if you use the different height settings on a regular basis to prevent the bags wearing or cracking through lack of use.
Any recommendations would be appreciated. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #259523 15th May 2014 2:53pm
mjdronfield
I just move mine between the heights every so often......
Not sure if you can do any "real" preventative maintenance. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #259525 15th May 2014 3:23pm
Flashman
I try to set it in offroad at least once a week and always park with access height so as to make sure it keeps the rubber supple and used. I only worry as I had to get all the bags replaced on my old 1994 Classic but the ones on the L322 seem to be much more reliable and long lived. Tom
Current Drive
Previous Drives
Post #259529 15th May 2014 4:06pm
clean the 'shafts' of dried up mud/muck... its surprising how abrasive this can be on the airbag rubber.. ... - .- -.
Post #259530 15th May 2014 4:16pm
I reckon a good clean and a "lube" every so often wouldn't hurt - but which is better vaseline, lard or axle grease? ( you have to know the song!) - Seriously: petroleum or silicon any difference? .
Post #259540 15th May 2014 6:26pm
dingg1
if you're going to lube it up use silicon based
petroleum and rubber products are generally not good together
Post #259545 15th May 2014 6:53pm
@ dingg1 Thumbs Up .
Post #259574 15th May 2014 8:57pm
Flashman
On one forum they were talking about silicon Shin Etsu as a product to treat the air suspension bags of a Lexus. Tom
Current Drive
Previous Drives
Post #259613 15th May 2014 11:13pm
Don't use anything that is sticky as it will just attract dirt and wear the bags out quicker Pete
Post #259641 16th May 2014 8:19am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Something like 303 Aerospace probably wouldn't hurt.
Post #259660 16th May 2014 9:54am
