![]() | Home > In Car Electronics (L322) > My hybrid tv tuner problems |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35728 ![]() ![]() |
press auto and it should come up with a channel list, if it doesnt move to a different location....although your house might get digital via a roof aerial the FF needs a strong signal to work.. ... - .- -.
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
It's worth going into the boot compartment (N/S) and check then re-check every single connection on ALL of the modules in there..... 2006 4.2 SC
I'll check again but I wouldn't get static screen if it was connected properly..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
As a test try connecting up to your house aerial (easier said than done!), then at least you will know if it is a signal problem or a tuner problem..... .
i still think that you should try and find a very strong signal area....the old analogue was different in that a weak signal could be picked up and you would get a fuzzy picture but you dont get that with digital ,its either received or not.. ... - .- -.
I don't have terrestrial tv in me home, only sky..
So I think I have figured out why the tuner won't work. Ireland uses mpeg4 for digital tv whereas uk uses mpeg2.
i thought mpeg4 was for hd broadcasts and mpeg2 for sd broadcasts..
done a google and found this,
We use mpeg 4 for sd whereas uk use mpeg 4 for hd. I think uk will be catching up in few years and changing to mpeg4, but at the moment it causes a lot of trouble for us in ireland. Lot of tvs and digiboxes are bought from uk suppliers and people have been stung to find that the equipment won't work here |
apparently freeview HD tuners will work over in southern ireland [i think] but that doesnt help you unfortunately..
Thanks for that stan |
have you RSE lolo?
