Home > Maintenance & Mods (L322) > 6HP26 oil and filter change
mpirie
Hi guys,
It looks like i have a leak from the mechatronic connector at the rear of my transmission.
I had a look in Wiki for advice, but only found reference to the 5HP and to getting it checked at the dealers.
Has anyone done a filter and oil change on the 6HP? I have to take the pan off to release the electrical connector so wanted some guidance on things to watch out for.
Also, what's the best oil to get and what quantity? I see 9.5 litres from dry, but assume it's less for a drain and filter change?
Thanks,
Mike
Post #259563 15th May 2014 8:10pm
http://www.fullfatrr.com/forum/topic25131.html
Thumbs Up ... - .- -.
Post #259565 15th May 2014 8:15pm
mpirie
Thanks Stan, that's the link i referred to earlier about getting it done by a dealer.
I wondered if anyone had actually done it themselves.....before I do Shocked
Post #259566 15th May 2014 8:19pm
Craig done mine recently , i watched him do the job and it looked pretty straight forward , mind you he is an expert so he probably made it look easy.. ... - .- -.
Post #259567 15th May 2014 8:21pm
Pretty much the same principle, personally i got the stealer to do it as it is only around £100 labour and you would have to buy the parts in any case.
Plus they have the tools, ramp, diagnostics to check the temperature of the box when filling (important) There is nothing that can't be fixed with a hammer😜😜
Post #259569 15th May 2014 8:26pm
