Home > Maintenance & Mods (L322) > Tow Bar Fitting whoe's
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Decided to fit a tow bar myself. Got a good quality bar and dedicated electrics.
Got all the gubbins out of the boot, rear bumper off so far all going well. Put plenty of WD40 on the four bolts holding the two brackets under the car and went off for a cuppa to let the WD40 do its magic.
First bolt a little pressure no problem, loosened it off a few turns, second bolt the same, third bolt put a little pressure on it and bang it sheared off Big Cry Censored . It sheared so easily that I can only think a previous owner has made an attempt at it before and realised that he couldn't shift and gave up.
I guess all I can do now is take it to a garage and see if they can drill the bolt shaft out and re-thread the hole Censored
Anyone else had this problem?
Post #259582 15th May 2014 9:10pm
Unfortunately thats about all you can do. You could attempt it at home but as a safety critical part its probably best left to the pros👍 There is nothing that can't be fixed with a hammer😜😜
Post #259594 15th May 2014 9:34pm
Useful vids on extracting sheared bolts
Post #259607 15th May 2014 10:33pm
iphs
Thanks for that fellas.
Post #259778 16th May 2014 7:25pm
iphs
All sorted despite the so called experts sucking air and shaking heads Rolling Eyes . Just needed a little ingenuity Idea and perseverance.
Where theres a will theres a way. Very Happy
Post #259917 17th May 2014 3:13pm
