Home > Maintenance & Mods (L322) > Air Con is STILL NOT WORKING |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
In my experience, a regas only is a false economy.
17th May 2014 9:36pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
^+1 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
17th May 2014 10:11pm |
It may well be, of course, that ATS do a pressure test first in any case.
17th May 2014 10:20pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7651 |
As SKOT says, Air con chaps will not be allowed to let it vent to air. They will prob use a vacuum to get the remaining refrigerant out and then do a leak test.
17th May 2014 10:29pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
You are all quite correct. ATS do conduct a pressure test first, all being well they will then do an antibacterial flush then a re-gas. |
18th May 2014 8:55am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
Is your air con compressor working as mine does not. I took the under shield off and checkecked and the clutch is not locking up but have not looked into it anymore. |
18th May 2014 11:40am |
I haven't looked, I would not know what to look for or what I was looking at. |
18th May 2014 3:20pm |
I'm not 100%, but I don't think the air con will engage if the gas is low, so the clutch etc could be fine, but the interlocks on the system will stop it engaging. 2011 Range Rover Vogue SE 4.4 TDV8
18th May 2014 5:09pm |
ERMMMM , yep, that went straight over my head
18th May 2014 6:17pm |
in other words, nothing will work until it has gas in it. That's your first port of call, as you correctly intend to do.
18th May 2014 6:20pm |
I thank you Sir.
18th May 2014 6:27pm |
I have re-gassed three Range Rovers at the Halfords Auto Centre and from warm air to perfect VERY COLD aircon working brilliant. My car was done 6 month ago and is still ICE COLD so there were no leaks. Older cars simply run out of gas... |
18th May 2014 6:41pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
My freezer in my garage is 15 years old and it hasn't run out of gas yet.
18th May 2014 7:39pm |
Three years I would be concerned too!
18th May 2014 7:42pm |
