Home > In Car Electronics (L322) > iPhone phone book
Bobster67
Scotland 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
iPhone phone book
Hello all, recently picked up my 2011 Vogue TDV8 and have a question about iPhone compatibility.
I have an iPhone 5s which works quite well with the new car however one issue is that only half my phone book uploads which means I am unable to search on many of my contacts and the caller I'd doesn't work for those numbers not uploaded.
Anyone else had this, any ideas.
Dealers usual response is to refer me tot he compatibility page of huge land rover website.
Thanks
Post #260045 18th May 2014 12:21pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I think it is an iPhone setting issue not a problem with the Rangie BT.
In the settings of the iPhone Bluetooth, you can set the numbers to sync. I think the default is only "Favorites" and "recent".
To change, on the iPhone go >Settings>Bluetooth then touch the "(i)" next to the Land Rover on the list of devices. This brings up a page which allows you to choose the contacts that you sync. Tick "All Contacts" and you will now sync everything.
If you don't want everything (I have hundreds and I don't want them all, you can create a group in the Contacts app that only as the ones you want (I have a "Car" group).
Hope that helps.
Post #260119 18th May 2014 6:59pm
^ really useful info👍
I also have loads of contacts and tgat means its a pita to search the
List when in the disco. There is nothing that can't be fixed with a hammer😜😜
Post #260121 18th May 2014 7:09pm
Bobster67
Thank Emperor Mong, good steer. I have checked my settings and have the following ticked the following:
Phone Favorites
Phone Recent
All Contacts
Problem persists. Could it be that there is a limit to the number of contacts that can be sync''d?
Also, I will try your suggestion of setting up a list of "Car Contacts" might be a good enough solution.
Cheers
Post #260133 18th May 2014 8:10pm
Googsy
I have same issue on my S4. I think you need to make sure contacts are saved to device and not sim or sd. Still I seem to have contacts that only appear on my phone and not when connected via Bluetooth meaning I have to use handset whilst driving to find a particular contact which isn't good. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #260162 18th May 2014 9:46pm
p38arover
Australia
Thank you. This works with my iPhone 6s and the BMW ULF I've installed in my L322. I set it up last night. Bow down Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #520683 5th Jul 2019 5:55am
