Home > Technical (L322) > Fuel Gauge - Not sure if it's working properly
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
Hi, I had the same problem, is the sensor of the tank on the left that does not have a home of their own, but it is let out into the tank, I solved it by taking the support level probe from a bmw x5, and shove the sensor level .. ...
Post #261195 24th May 2014 12:19pm
madcima
this is the one, original mounted without support
Post #261196 24th May 2014 12:28pm
Andy
trainmanone wrote:
did you ever get this sorted??
no. I learned to live with it over time. I keep saying ill do it one day, but after 5 years of owning it, I've got used to it now!
Post #262040 29th May 2014 8:39am
ebajema
Just have a can of fuel in the back just in case Wink Doesn't work for the SCs though, we need a bloody big tank to get to the next petrol station Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #262042 29th May 2014 8:44am
Rextter
United Kingdom 2002 Range Rover HSE 4.4 V8 Barolo Black
I'm having this problem too in my 2002 petrol L322 4.4L. I set off for a 25 mile journey and my petrol gauge was on a quarter. When I started for home the needle went up to half. I called in at my Shell garage and put £100 of V-Power in the tank (76 litres). So the tank must have had about 22 litres left when I filled up (about a quarter of a tank). After filling the needle remained on quarter full and the figure displayed for 'Range' on the screen also stayed at 178 miles.
Did anyone find a fix for this?
Post #293478 16th Nov 2014 3:13pm
New pump and sender is pretty much the only way. There is a how to in the wiki I think for the earlier cars, basically same as changing the im tank fuel pump.
http://www.fullfatrr.com/forum/topic16152.html
Pretty much same procedure except not replacing the pump inside the housing. This shows one side, there is then a cross over pump under the other hatch with a float on too.
I think on the earlier cars each side is available separately, so best to test the rheostats on the floats to determine which has gone. There is nothing that can't be fixed with a hammer😜😜
Post #293483 16th Nov 2014 3:20pm
Rextter
That was an incredible reply Amzingmonkeyjones, Thank you Smile
Post #293536 16th Nov 2014 7:05pm
OK... there is a TSB about this issue (more so on later FF's but covers all the age range)
So, in short... There are two pumps in the tank (one each side) they read an average reading from the two pumps. The secondary electrical plug (blue) inside the tank fails to read one pump so reads an average of "one side" empty & "the other side" with fuel giving a reading between a 1/4 to 3/4's... Not full or empty...
The resolve is to cut the faulty blue plug off and solder the wires together... Removing the dodgy blue plug from the equation permanently... Thumbs Up
So, worth checking this resolve before replacing your expensive pumps!
PLEASE DONT FORGET... SAFETY FIRST GUYS!!! Fuel & soldering don't go together!!! Bow down Embarassed Bow down
Post #293653 17th Nov 2014 12:55am
