![]() | Home > Maintenance & Mods (L322) > Auto 'dipping' passenger wing mirror? |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Not sure when the introduced the dipping mirror but I had it on my 54 plate touchscreen TD6. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7961 ![]() ![]() ![]() |
Mine will do it provided the selector switch for which door mirror you adjust with the adjuster is set to the drivers mirror - if that makes sense ?
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
Same on 2003 Vogue. Switch set on drivers side and it dips when reverse selected. I don't like it though. |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 ![]() ![]() ![]() |
^ + 1 , hate it Current : 4.2 S/C, now Sold |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
Even my old p38 had it Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
Well I can confirm I've selected drivers side on the mirror button and it doesn't dip at all |
On the bmw's of a certain era, you only had this feature if you had memory seats. As yours is a Vogue, it will have them.....
I actually really like it when reverse parking as it allows you to see how close your rear wheel is to the curb as you reverse in, and can save scraping your alloys up while getting you as close to the kerb as possible. This can avoid the car sticking out to far, and being as the RR is wider than the average car many parking spaces in towns/citys are pretty tight on width.
I wish it would do a single wipe of the rear wiper if the fronts are on and reverse is engaged, like on the Discovery 2....... 2011 Range Rover Vogue SE 4.4 TDV8
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
You know I could have sworn my 2004 wipes the rear window once if the front wipers are on and reverse is engaged..... will have to test tomorrow! Current Fleet:-
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
The rear wiper does but only if the fronts are on constantly i think... |
Same as mine if the fronts are on the rear wiper comes in to action when reverse is selected and both mirrors dip ====================================
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Andy, you need to tell the mirror what position to be in.
That's what I was getting at, but couldn't remember the procedure........hope that solves it.
