Home > Technical (L322) > Coolant Bleeding on 4.2SC Aaaarrgghhhh!!!!!
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Been trawling around looking for some solid info on this. I suspect my head gasket (s) may be gone, but before I condemn it I want to get coolant running properly around the engine.
I gave my car to my brother as he blew the gearbox up on his Audi. A coolant hose on the LPG system cracked (poor quality hose) and he lost coolant and said the heater went cold. Don't know how long he ran it but he says he stopped quickly.
So..... I have the car back at my place (I trailered it home) and I have replaced the damaged hose. Problem is when I try to fill it the system pressurises the hoses and it overheats after about 5-10mins ticking over. Top of radiator is cold, large hose on right hand side of radiator (as you stand look into the engine bay) is stone cold. It just seems like the water is not getting around the engine. Is there a fail safe way of bleeding these things? Are there any special bleed screws? The head gaskets may well be gone, but I'd really like to make sure it's not just failure to circulate due to air, thermostat, water pump etc.
Any ideas?
Post #261274 24th May 2014 9:10pm
dingg1
could well be just an airlock (fingers crossed for you) but does sound more ominous tbh
there is a bleed screw on top of the expansion tank , open that and start the engine with the expansion tank cap off top up as it warms up or tank level falls
good luck
Post #261289 24th May 2014 10:01pm
marcoos_1
OK, I'll give that a go .....I'm not too confident though, like you said ......sounds ominous.
Can anyone recommend a good product for testing the coolant for exhaust gases?
Post #261361 25th May 2014 1:17pm
ebajema
My system has been completely empty due to my gearbox and engine oil coolers rupturing (internally) so my system had to be bled twice.
The trick is to keep going with the engine at idle and keep filling up, bleeding via the little tank.
The car should be level (or at least that how mine was done).
Just keep it going (takes some time, i.e. hours) and when the engine overheats, just let it cool down.
Maybe also replace the thermostat as it should open but it sounds like it doesn't.
The LPG conversion may have changed the cooling system such that it allows air to stay trapped in it. So you could look at high points in the cooling circuit and bleed at the high points. MY 2010 5.0 SC Galway green and sand interior!!
Post #261362 25th May 2014 1:37pm
pld118
@marcoos -
You could also read this coolant tank bleed screw thread with pictures that might ( or might not be) of some assistance.
http://www.fullfatrr.com/forum/topic21436.html?highlight=ptfe
Post #261438 26th May 2014 9:12am
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
maybe your waterpump is kaput . . . which caused the other prob....................I stress the word MAYBE 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #261439 26th May 2014 9:32am
