![]() | Home > General (L405) > radio regional change help needed. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35772 ![]() ![]() |
i suspect you would have to replace the tuner with an european one to get the even numbers.. ... - .- -.
buflanfx45 Member Since: 28 May 2014 Location: middle east Posts: 5 ![]() ![]() ![]() |
Thank you stan for the reply. But would the dealer be able to replace only the tuner?
i'd have a word with a dealer and ask if this code change is possible, i'm sure you're not the first to import a car in this situation.. ... - .- -.
USA spec and European spec radio FM tuners are different. I recall this in the days when the Nakamichi TD1200 was only available with a USA spec tuner. Fine if you give it a strong signal and it's on a frequency you can select but generally speaking a US tuner outside of the USA is about as much use as tits on a bull. It has to be changed for a regionally correct one. |
Thank you for the reply. Just for the sake of discussion this was not the case with bmw. I had 2011 x6 imported from usa and i have found a person that does re coding for the software and changed the regional setting and it was all good. In addition i have seen a thread in this forum to do this chane for RR sport 2012. |
the old sport probably uses a completely different firmware system than the very new l405 ...asking the dealer is the first step.. ... - .- -.
Maybe contact Steve of Gap Diagnostics. He may know and their IID tool may have the functionality built in to change the region and therefore hopefully the tuner settings |
i have already looked on the GAP site and there isnt a l405 listed [yet |
I am out of luck, GAP had replied to me that they can not do anything now but maybe end 2014.
doesnt yours have dab ?.. ... - .- -.
Faultmate (Blackbox Solutions) does have the L405 software already but their systems are a lot more expensive than the IID Tool. I have a Faultmate Xtreme because I didn't know about the IID tool at the time. MY 2010 5.0 SC Galway green and sand interior!!
what is DAP??
Digital Audio Broadcasting ... - .- -.
can you not enter the frequency manually and save as a pre-set?
