Home > Maintenance & Mods (L322) > New FFRR owner - some funny noises
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Hi Everyone, i've had a look through the forum and i'm still a little bit concerned at the mo.
I've picked up our new car today,
4.4 Vogue 03/53 reg, with LPG. the difference between this and my old discovery is immense, so i'm hoping these next few thing are just quirks i need to get used to and not faults. i need someone with experience of FFRR to guide me as to whether these things are normal;
1) there's a slight buzzing / whirring sound coming from near the clock. its there when i open the car, before switching anything on.
2) there's an intermittent sound from the OSR which sounds like driving over rumble strips.
3) there's an intermittent vibration coming through the car, felt in the seats and steering wheel. this isnt present at the same time as the noise from the rear.
the car is under warranty for 3 months. it was MOT'd yesterday and passed with 3 advisories - both front tires worn on inner edges and a slightly cracked rear tyre. all these were done by the garage.
cheers
jake
Post #261951 28th May 2014 7:44pm
davidjpowell
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
1. is a small fan to feed air to climate control sensor... Asked the same question with the same noise!
Post #261977 28th May 2014 9:55pm
ebajema
There is a post here (maybe even in the Wiki) about how to remove the climate control panel and cleaning the fan and sensor. Over the years the fan collects dust and that reduce the effectiveness of the cabin temp sensor and can cause the noise. I think Daveo did that post but not sure. Stan may be able to help as he is a super search guru on here (or he has an eidetic memory).
The other vibrations could be caused by external trim (bonnet and A-pillar are notorious for these issues) not being fastened properly or coming loose. So I would suggest to start searching there first before looking at more sinister things happening. Also underneath the car there are covers/wheelarch liners and the likes that could be loose and cause the noise/vibration. MY 2010 5.0 SC Galway green and sand interior!!
Post #261994 28th May 2014 11:38pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Congratulations on your new FFRR!
When you say "all these were done by the garage" does that mean the tyres were replaced?
Anyway to answer your questions:
1) Buzzing whirring is the fan for the temperature sensor for the climate control, it's a normal thing on most cars although shouldn't be too noisy but is clearly audible when getting in the car. It tends to suck in dust which can make the noise worse.
2) & 3) Unbalanced wheels on the front (due to tyre wear) often give vibration through the steering wheel. Cattle grid/rumble strip like vibrations over 50-55mph can also indicate a worn out torque converter. It could also be worn suspension components/wheel bearings etc. but they should have been checked in the MOT, all depends on the inspector. If not done already by the garage and you are getting advisories on the MOT I would get the tyres changed and balanced and see if it improves.
Post #261998 28th May 2014 11:44pm
jakebullet64
Chees for the replies.
3x new tires . Both front and OER.
I'll have a look at the fan today hopefully.
Jake
Post #262020 29th May 2014 6:44am
Vibration felt through the seats is most likely to be rear wheel balancing.
If you're getting the rear tyres replaced, do as a pair, get them properly balanced. I've often taken mine back a couple of times to get the wheels re-balanced as they didn't do it right the first time. Discovery 4 HSE
1993 90 Tdi
Post #262035 29th May 2014 8:22am
jakebullet64
hi, thanks for that,
it kind of makes sense as the OSR was replaced on the 27th may.
i'll get it balanced later today.
cheers
jake
Post #262046 29th May 2014 8:52am
