![]() | Home > Technical (L322) > Fuel Gauge reading |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
We have a 2003 L322 V8 petrol. The fuel gauge never reads higher than 3/4 full even though when it is refuelled to the point at which the fuel nozzle starts to click off.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
As has been said, like most BMW's of the era, the tank has twin senders due to split nature of the tank. If one is dodgy it won't get to the full mark. If it was OK before the dealer did the fuel pump it's likely the sender on that side hasn't been set up correctly, I had a similar issue but on a different BMW.
Thanks for the replies. From what has been said it sounds like it could be one of the senders faulty. The dash hasn't been touched and it does lie on 0 when its off.
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
mine is the same after replacing the in tank fuel pump ,have you sorted it yet?? if so what was it ?/ have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Mines the same. It also runs out of fuel at around 70 miles left so I think I have a dodgy sender |
