![]() | Home > Technical (L322) > No fan |
Sounds like the very common FSR problem. Have a look around, several posts on that and how to replace. Good luck. MY 2010 5.0 SC Galway green and sand interior!!
Jim Member Since: 04 Feb 2013 Location: Tasmania Posts: 27 ![]() ![]() ![]() |
Gday.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
fsr stands for 'final stage resister'.....we have a great search function, stick those words into it and loads will be revealed.. ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
Final stage blower resistor, relatively cheap to replace.
Gday everyone who replied so quickly and thanks for that. As you can see by my collection of cars below my 2003 L322 is the newest and all these electronics are driving me mad. Give me the old stuff anyday.
Jim, not the best of video's but have a look at this and you will see where it is above your left foot when sat in a RHD FFRR |
Gday.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432 ![]() ![]() |
The rear fans are on a separate circuit and have their own FSR I believe.
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
Where did you buy the FSR from? I had same issue with a 'cheap' replacement one from ebay, got one from dealer for maybe £15 more than the ebay one and it worked straight off. Exactly the same issue as you, lights all came on as you turned the blower up but nothing actually happened. Good luck |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
sounds like the blower motor has given up ,had same problem I did mine last year mrd 1990 did a howto in the wiki hope that helps have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
G'day all.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Glad your getting it sorted, have you checked to see if it has a cabin filter, sounds like it may have been taken out, this would let dust/sand in and wreck the motor....
Gday.
