Have you tested the battery and generator yet ?? Start with simple voltage test engine off and running to see the difference in voltage.
Batteries can die/reduce when getting old so they won't hold charge even if the generator is putting enough in.
Have a look at the age of the battery, fluid level (if not sealed), check the clamps on the poles (corrosion reduces the voltage due to extra resistance) etc. etc.
All simple stuff but on a FFRR lowish voltage is a big issue, the ECUs have a hard time doing their work and start throwing up faults. MY 2010 5.0 SC Galway green and sand interior!!
