![]() | Home > Technical (L322) > Faults everywhere and IID tool not working! |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I tried 0000 and it worked.
Bit of an update:
Sounds exactly like what I had, Noddy. I assume you found no direct traces of humidity by what you are writing?
It's still faulting. I've yet to get a few hours where I can look at this properly.
I reset it again tonight in the car park at work. As soon as I turned the steering wheel, it faulted again. HDC inactive and Airsusp inactive
PatGAPInnov Site Sponsor Member Since: 01 Dec 2011 Location: Montreal Posts: 153 ![]() ![]() ![]() |
Would be worth looking at the steering angle senor live value. These have been known to fail... |
Ok.... What am I looking for? |
When the wheels are straight, it should be equal to 0. Slowly turn the wheel in one direction. The value should change accordingly. If you see it jumping quickly, your sensor is not working properly. |
I think I've found the fault.
Here you go...
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Well done Noddy, glad you found the fault. |
Pat, I would use shrink tubing but I can't get it over either end of the cable. There's a black box at one end and the other goes to the unit on the back of the hub.
Indeed, shrink tube is sometimes hard to fit !
So, you crashed the CAN (isn't that an ancient song by Suzy Quattro or someone?).
