![]() | Home > In Car Electronics (L322) > Sat Nav Radio screen setting when you start your FF |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
Mine stays at where it was when I turned the car off.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Mine goes to the splash screen then switches to the last screen selected with the exception of the tv which if previously used will still need the select button pressed before the picture and sound will display. |
| netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165
so i may not have something set right, any ideas...........no voice control unless my wife is in the passenger seat |
Is it the standard mk3 unit, with off road navigation in the menu, or is it a mk4 upgrade ?
standard |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Original equipment: (Usually always listening to radio on switch off) - on start up: splash screen, computer menu, radio menu .
| All times are GMT |
