![]() | Home > Camping, Caravanning and Holidays > 7 or13 pin |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
funny, my 2002 has a 13 pin on the (original) armature, with a small 13-7 pin screw in converter. -and I would need to use a y piece accessory to change it to a twin grey and black etc. I think you can buy the loom part like this to directly plug into the car loom. ie 13pin
Buy a new loom part. Depending on year they are slightly different, the 2010 ones are a lot shorter but not overly expensive and vastly superior to the 'Y' type converters which are available.
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
Thanks for the replies guys.
Like most things in life, there are cheap versions of everything. The LR genuine 13 pin socket is hard wired with potting resin at the back to keep it all waterproof and is a very good quality item. Mine was used every fortnight for over 2 years on my old car and was absolutely fine.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
13 pin socket is a testable item for an MOT whereas two 7 pin sockets are not. Fitting one just gives something else to fail an MOT. Adapters are not testable items. |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 ![]() ![]() ![]() |
7 pin sockets have been used since i was a lad and probably years before that, Why? because (looked after) they work.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8777 ![]() ![]() ![]() |
Disagree with some of the above.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8119 ![]() ![]() ![]() |
It's easier than that
^^ also true, and easy to do, though i would argue marginally less robust, and a lot more fiddly than pulling out the old loom and laying im the new one, about a 15 min job i would say...... There is nothing that can't be fixed with a hammer😜😜
Just because something's as old as the hills doesn't mean there isn't a better solution. If we all followed that logic we'd still be driving the first of the steam powered cars.
My 2012 Coachman came with a genuine Jaeger plug from new so not sure where you get that impression. Possibly some budget caravans have cheap plugs, but they'd have cheap 7 pin ones if those were still in use. Bottom line is that the Jaeger 13 pin plug is vastly better thought out, better engineered and much more reliable. No overloaded earth pins to get hot and melt the plastic, no copper pins to corrode and a positive locking system to keep it in place. |
