![]() | Home > Technical (L322) > TMC problem - solved! |
| Turnover Member Since: 27 May 2014 Location: Norwich Posts: 39
Hi whereabouts was this aerial connector as I'm having the same problem.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
My TMC problem is the gap between transmitter and receiver , about 12,000km |
| Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
off side cubby hole [i think]
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Its on the near side (of a UK car). Pull off the left hand (as you look at it from the back) side cover and if memory server, it's above the wheel arch. Looks like a fag packet sized box.
Thanks for that. It was where you said. LHS rear compartment. It's got TMC on it in big letters which was a bit of a giveaway. |
I managed to get that cover off without breaking anything |
hope this helps,
Yes I had found that but it seems there is a bit of confusion in the workshop manual. The text that you posted says the aerial is located in the RH rear glass but both back glass windows contain the TV aerials. So the TMC module on the tailgate must connect to the rear screen somehow. This detail isn't contained, unless I've missed it, in the workshop manual.
| All times are GMT |
