![]() | Home > LPG > DIY LPG servivcing |
jaipal2004 Member Since: 13 Dec 2013 Location: Wednesbury, West Midlands Posts: 85 ![]() ![]() ![]() |
Hi,
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Me:
Mine is an EMR one |
Do you mean EMER?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
If it's set up and running Ok and the emissions are alright then the only bits to service are filters in the solenoids, usually one at the tank and one at the vaporiser. After big miles the vaporiser can do with a clean out as you get deposits build up, need an overhaul kit that comes with a new diaphram etc Only really need to plug in the ECU if you have faults or it's not runing OK, if it was set up well at install then it will follow the cars ECU and compensate all on it's own... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
The question is, why hasn't it got one... If it's been lost, not a problem as it will have been recorded on the LPGA website... If it never had one then was it a DIY install and if it was does it comply with LPGA guidelines... Get it checked by a registered installer, he will asses the install and can issue a certificate there and then if it's OK... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Jonno..... Yeah sorry... I meant EMER |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Checked the LPGA website, it's not recorded there, so I guess it was a DIY job. That then raises the question of wether it was fitted correctly of not. ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Yeah I did the same.
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
Same for me,check if the previous owner was on a private plate, then check that reg |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Your insurance company may need a certificate before they insure the vehicle. Also it may not be registered with the DVLA as a dual fuel vehicle. Which means you won't get the cheaper road tax. ![]() |
I did check and they've not requested one as yet.
Insurance companies only usually ask for the cert if you make a claim, if you haven't got one they won't pay for any LPG bits and may refuse the whole claim, not many ask for it when you take out the insurance.
Any reduction no matter how small should be snatched from the government at the first opportunity as a matter of principal. ![]() |
