Home > Technical (L322) > Dead Battery
ARH Vehicle Logistics
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Dead Battery
Good day all full fats I know that this may have been covered in older threads but just can find it and getting desperate!! yesterday morning my wife went to go out in the fullfat and couldn't get in the battery was completely dead (looking at the door lock now) i got home called the aa who showed me how to put power to rear of alternator to get power to unlock doors great!!!! changed battery and went out last night all fine got home 8pm parked up all great, was woken up at 4 am with the alarm going off as battery had died again. Any ideas???? what to check? Please help as i am away next week and cant get the car to a garage so i need to find it today really checked all the obvious things lights ect.... If i could would you!!!!
Post #263811 7th Jun 2014 11:09am
Was the new battery fully charged ?
Clearly something is draining it - could well be a dodgy alternator - basically, you need to figure out what's causing the drain.
If you can't, leave the battery disconnected - if you drain it too far, you will knacker it.
Post #263813 7th Jun 2014 11:15am
yes battery was fully charged and is 110 ah, I have just sat in the car for 10 mins with it locked and heard a low humming as if a fan had come on could this be it? If i could would you!!!!
Post #263814 7th Jun 2014 11:21am
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
As I understand it, the fan you can hear is common to all of them. I was surprised to hear it the first time. I am amazed how many things seem to remain powered on for quite a while after turning the ignition off.
I would suspect an alternator fault if a new battery went flat as quickly as that.
Post #263819 7th Jun 2014 11:33am
I'd get the AA back out as they clearly didn't do enough diagnosis in the first place.....
Post #263821 7th Jun 2014 11:42am
FSR is one of the top culprits for this but as stated above... Call the AA out again Thumbs Up
Post #263823 7th Jun 2014 11:51am
thanks for the replies! I have un plugged the fsr but the fan I am talking about is still running, the vent by the footwell light Next to the big grommet you have to take out to release the undertray is where the noise is coming from. Should this still be running after the ignition has been off for 40 mins? should I go and get the battery and alternator tested If i could would you!!!!
Post #263827 7th Jun 2014 12:29pm
ebajema
Mmmm 40 mins sounds a bit long to me. Suggest to download the workshop manual of the car (Wiki should have a link) and dive into that. MY 2010 5.0 SC Galway green and sand interior!!
Post #263852 7th Jun 2014 2:36pm
The fan you hear takes 20 minutes to stop once the ignition key is removed and the vehicle allowed to go to sleep. If it takes longer than 20 minutes you need to investigate to find out why
Post #263859 7th Jun 2014 2:53pm
Had the AA man out again, started car and ran a few test but wasn't that confident with the car! he did find that the alternator is charging at 13.2 and when put under load ie lights heated f and r screens on with blower fan and the voltage dropped slowly but surley thus indicating an alternator problem and has told me to replace the alternator as its not working as it should and could be shorting when sat idle!! what do you think guys. If i could would you!!!!
Post #263899 7th Jun 2014 9:31pm
the alternator should be charging at around 14.5 'ish on normal idle..this isnt a lot different to you reading but it could make the reason ... - .- -.
Post #263905 7th Jun 2014 9:48pm
you certainly should have more voltage out of the alternator than that. I suspect you diode pack on the alternator is failing. Is the ignition light glowing at all?
You can test for battery drain down thro the alternator overnight by simply disconnecting the large 35mm2 cable from the +ve jump stud where it passes thro the bulkhead. Your battery can't drain thro the alt then.
In the morning reconnect the cable and try and start your car. If it starts ok it tends to suggest you need a new alternator.
If it doesn't start the drain is elsewhere.
You really need to invest in a multimeter. Thumbs Up
Post #263915 7th Jun 2014 10:30pm
kiter
I had this same problem a few weeks back and had to pull the 2 fuses for the blower to get the fan to stop running, mine was down to a duff FSR and fan just came on when it felt like it, even with iginition off. I bought a cheap FSR off fleabay and it didnt work, last week I finally got a genuine land rover one (£45 inc vat), installed it and all is well again. Smile
Post #264018 8th Jun 2014 4:35pm
hi how long did it take to drain the battery? If i could would you!!!!
Post #264046 8th Jun 2014 6:44pm
kiter
I reckon it was about 11 hours, set the alarm going which completely flattened the battery, it was early doors one morning and I did hear the alarm but assumed it was construction equipment next door as they were getting major landscaping done so just ignored it - RR alarm sounds like a lorry reversing.......... Day before car had a good long run and had started fine etc. I got the battery checked out and it was replaced as said it was knacked.
Few days later same thing (by this time I had fixed the door lock so it could be opened with the key) - it was then I started to look for a cause and realised fan was keeping going. Problem seems to be solved now with a new FSR.
Post #264061 8th Jun 2014 8:57pm
